Remote Panel Server with .NET Interop-Assembly
Hi guys!
I have here a LabVIEW 2014 project which was compiled into a .NET Interop Assembly.
Now I try to activate the LabVIEW Remote Panel Server for the assembly.
Apparently it seems to be active.
But for every VI i get the message that it is not in memory.
But I am sure that these are in memory.
When I compile the project to an executable, everything runs fine.
Does anyone have a hint what I am doing wrong?
the content of the ini file (InteropAssembly.ini):
[InteropAssembly]
server.app.propertiesEnabled=True
server.ole.enabled=True
server.tcp.acl="290000000A000000010000001D00000003000000010000002A10000000030000000000010000000000"
server.tcp.enabled=True
server.tcp.port=3361
server.tcp.paranoid=True
server.tcp.serviceName=""
server.vi.access="+*"
server.vi.callsEnabled=True
server.vi.propertiesEnabled=True
WebServer.Enabled=True
WebServer.TcpAccess="c+*"
WebServer.ViAccess="+*"
DebugServerEnabled=True
DebugServerWaitOnLaunch=False
