dcoons Posted May 20, 2020 Report Posted May 20, 2020 Has anyone used the functions located in vi.lib to programmatically edit Installer build specifications? I have used the functions in AB_API to edit Packed Project Library build specifications (in PPL subfolder) but cannot find anything equivalent for Installers. The classes in this hierarchy inherit from NI_AB_API_Build.lvclass which has a generic open method, but installer is not in the list of selectable build types to open. I also found IB_Classes subfolder which has functions for interacting with Installers maybe, but there's no clear function to open an Installer build specification to start editing. I have a template project where I need to change three parameters for the Installer when the template is copied/edited: destination.name for one specific destination, INST_bldLocation, and INST_productName. This is an example of updating a few of the build specification items for a PPL (just need the equivalent for installers): Quote
dcoons Posted May 21, 2020 Author Report Posted May 21, 2020 Here is an example project to entice you more. Template gets copied, library gets renamed, a few edits to the PPL build, and then I need to edit the installer. I am pretty sure I can use the tags like below - but I know that isn't the best way to do this. Example Project.zip Quote
Darren Posted May 21, 2020 Report Posted May 21, 2020 There is a different API for Installer Builder. It is also not officially supported by NI, but there are a couple of examples that ship with the API to help you learn how to use it: [LabVIEW 20xx]\vi.lib\InstallerBuilder\examples 1 Quote
dcoons Posted May 21, 2020 Author Report Posted May 21, 2020 Looks like this is what I need - here is updated project with some implementation to prove it out. Thanks @Darren Example Project.zip Quote
