drivers and sub VIs added to user.lib not showing up in User Libraries
mojo75
I was following the instructions in this manual (see pdf) for adding the drivers and sub VIs for this particular translation stage. The first step is to copy the provided directory under the directory Program File > National Instruments > LabVIEW20xx > user.lib. I'm using LabVIEW 2015.
When I got to the directory LabVIEW2015, user.lib wasn't there, so I created a folder user.lib and copied the necessary directory to it. When I open LabVIEW and go to User Libraries, what the manual says should be there isn't showing up.
What did I do wrong?
CONEX-CC_-_LabVIEW_Drivers_Manual.pdf
If you're using 32-Bit LabVIEW, you may have to copy it to the "x86" Program Files Directory at:
 C:\Program Files (x86)\National Instruments\LabVIEW 2015\user.lib
Edited by Bryan
