how to read or write 2D array from or to database
labsql or labview sql toolkit can only read or write 1D array one time. If i want to write 100 1D arrays to the database, it is too slow and will cost too many CPU time to do this by writing a single 1D array one time. :headbang:
So i wanna an efficient method. Can you help me? :rolleyes:
  • 4 weeks later...
As far as I know it is not possbile to write a 2D array to a database Table directly. You are fixed to the 1 record insert.
But there are a few possibilities and tricks
-Switch to the ADO.COMMAND object to insert you data binary! This will decrease the size of your SQL command.
-Dont use new SQL commands for every record, try to use a "prepared ado.command execution"
-You might redesign your database to insert a 2D Array as an IMAGE datatype, but this will only be read/writable by LabVIEW.
Arnoud de Kuijper
T&M Solutions BV - Database Wizard
