Multi-plot graphs and user-enabled drawing
I have two questions today:
How exactly does one make a multi-plot graph with two sets of data (as in two sets of x-values and two sets of y-values of array format)? I want the result to be in an XY Graph format (using LabVIEW 6.1 of course).
In addition, is it possible to allow the user to place points on a graph as input and allow the coordinates to be returned to an array? If so, is it also possible for the user to draw a line on the graph and allow a certain number of points from the line to be returned?
These may be simple questions but I would appreciate the help nonetheless :laugh:
5394[/snapback]
Okay, I found how to transpose multiple plots on a graph; I was just too lazy too look it up :) . But I have not resolved the second question.
  Wolfram said:
Use this as a start
Download File:post-1013-1122317126.vi
5397[/snapback]
Sorry if you misunderstood, but I already found out how to place multiple plots on an XY graph. Sorry about that. What I do need help with is enabling the user to place their own points and draw their own lines on a graph by using their cursor. I want the points to be returned to two separate arrays (one for x-values and one for y-values). This would be useful.
Thanks.
  pandaman said:
So does anyone know how to return values that have been drawn on a graph or even drawing on a graph for that matter?
5513[/snapback]
Have a look at this example:
...\LabVIEW 7.0\examples\general\uievents.llb\Draw Graph with Events.vi
-Franz
-Franz
5515[/snapback]
Sorry, but I don't have Labview 7.0 :headbang:. How would you do it in Labview 6.1? If the example is in LV 6.1 under a different name, please direct it to me.
Thanx
Thanx
5520[/snapback]
Search the examples under graph. They used to have a similar example for the older versions that didn't use the event structure.
Neville.
