Controlling voltage in a fast steering mirror using labview
Hello. I  have a fast steering mirror system (FSM-300) and a NI USB-6008 device. I am trying to control the x-axis and y-axis, so i can use it to scan anything.  I am attaching the file( which is the code) I am using  to generate the signal and introduce to the x+ command on the mirror controller.  I use oscilloscope to read the voltage and it doesn`t show sine waves. It seems like just some noise. I am not sure is my code wrong or my connection. I use labview 2020 community edition and daq mx of 21.3 version, so it doesn`t seem to be a problem. The photo is what I get on the oscilloscope.  I tried to change an oscilloscope and wires. The usb device seems to be working okay because its diode is turned on.
generate the signal.viFetching info...
