Linking two array indicator indexes
Is it possible to synchronize two array indicators such that when the index of one array is selected, the values of both arrays at this index are displayed?
Ex: An array of x-values and an array of y-values are displayed on the front panel. The user is allowed to select the point # (point 0,1,2...) in order to view the co-ordinates.
  mballa said:
Unfortunately there is no event condition when the index value is changed.
Use a separate control to feed IndexValue properties of both arrays and then you can use value change event.
post-447-1123534355.gif?width=400
