bjustice Posted November 18, 2022 Report Posted November 18, 2022 I ran into a situation where I need to return the class hierarchy of an object as a concrete object array. (If you are curious, this is used in the BlueSerialization toolkit) The following code snippet demonstrates how I accomplished this. Unfortunately, I just discovered that this algorithm doesn't work if a class also inherits from an interface class. (My algorithm here assumes that a class can only inherit from 1 other class.) Naturally, my immediate question is this: Is there a graceful NI primitive or mechanism for determining if a given object is an interface class or a concrete class? If yes, then I could just filter out interface classes in my code here and move on with life. I did find the "Get LabVIEW Class Parent and Member VI information VI. But, I can't get this VI to work recursively. On the 2nd loop iteration, this NI primitive returns that results for a base LabVIEW object even though the wire probe shows this as not being a base LabVIEW object. Get Class Hierarchy.vi Quote
LogMAN Posted November 18, 2022 Report Posted November 18, 2022 Interfaces have no private data control, which means you can just check if such control exists in memory. The original VI is available on GitHub: https://github.com/logmanoriginal/labview-composition ("Is Interface Or LabVIEW Object.vi") 1 Quote
bjustice Posted November 18, 2022 Author Report Posted November 18, 2022 LogMAN, thanks for the input. This certainly works in a pinch. I was really hoping that there might be something a bit more native. This also doesn't seem like it would be super fast to me. Quote
LogMAN Posted November 18, 2022 Report Posted November 18, 2022 How fast do you need it to be? Speaking about native solution, there is <vi.lib>\Utility\LVClass\Is Class Not Interface.vi <vi.lib>\Utility\LVClass\Is Class Not Interface Without Loading.vi However, these might not work at runtime. Quote
bjustice Posted November 18, 2022 Author Report Posted November 18, 2022 (edited) ooo, interesting. One of these isn't available until LabVIEW 2021 Edited November 18, 2022 by bjustice Quote
LogMAN Posted November 18, 2022 Report Posted November 18, 2022 Just in case you are looking for a solution that doesn't have to work in runtime, there is this property for class libraries. 1 Quote
bjustice Posted November 18, 2022 Author Report Posted November 18, 2022 yeah, it looks like the latter VI is doing exactly that. Opening the library reference, and then using that invoke node. I suspect that this is slower than your solution, but probably a bit more bulletproof Quote
LogMAN Posted November 18, 2022 Report Posted November 18, 2022 Not sure about speed, but these VIs use features that aren't available in earlier versions. However, if backwards compatibility isn't an issue, this is probably the most native way to go about it. As for speed, perhaps caching is an option? Quote
bjustice Posted November 18, 2022 Author Report Posted November 18, 2022 BlueSerialization is currently LabVIEW 2020. hmm... okay. How bulletproof do you think your VI might be? Would LabVIEW ever be "smart" enough to not load a classes' *.ctl file into memory if it was blank or something like that? Or perhaps drop it from a build if it were blank? If you think this is pretty bulletproof, I'll just use this and push a patch to the BlueSerialization library. I am already cacheing the results, so speed is probably not a huge issue. Quote
LogMAN Posted November 18, 2022 Report Posted November 18, 2022 That is very unlikely. It would turn classes into interfaces, which is a major breaking change. 1 Quote
bjustice Posted November 18, 2022 Author Report Posted November 18, 2022 Thanks for all the input. I'll go with this solution Quote
bjustice Posted November 18, 2022 Author Report Posted November 18, 2022 BlueSerialization v2.3.3 uploaded to VIPM. I improved the cacheing scheme a bit as well given this new code addition. Quote
