Thomas Granito Posted December 13, 2022 Report Posted December 13, 2022 Hello, I wanted to ask if it is possible to extract all rows from a 2d array for example of size 10x6. If so, how can it be done? Thank you Quote
Rolf Kalbermatter Posted December 13, 2022 Report Posted December 13, 2022 9 hours ago, Thomas Granito said: Hello, I wanted to ask if it is possible to extract all rows from a 2d array for example of size 10x6. If so, how can it be done? Thank you I'm not sure what you want to do. All rows from a 2D array would sound like the whole 2D array to be. When you mean a particular column that contains values for every row, just check out the Index Array function. If you connect a 2D array to its input it will expand to have one index and one size input per dimension. Connect the index value you want to have for either a particular row or column to extract and leave the rest unconnected. Quote
