Vijayalakshmi Posted August 19, 2005 Report Share Posted August 19, 2005 Hi all, I m trying to integrate Labview 7.0 (on Mandrake linux) to mysql 4.1 using C APIs. I use the labview utility - lvmkmf i.e lvmkmf my_conn (my_conn is the C program that uses the mysql C APIs) The C APIs require the library mysqlclient and I have included it in the Makefile using the CINLIB macro. And I get the following error. gcc -shared -o my_conn.tmp \ /home/viji/cintools/cin.o my_conn.o /home/viji/cintools/libcin.a /home/viji/cintools/libmysqlclient.a /home/viji/cintools/lvsbutil -c my_conn -t CIN -d `pwd` /home/viji/cintools/my_conn.tmp: undefined symbol: compress /home/viji/cintools/lvsbutil: error building resource file: 1 make: *** [my_conn.lsb] Error 2 Is the lvsbutil trying the compress the libraries and giving an error when trying to do so? Thanks, Viji Quote Link to comment
Jim Kring Posted August 24, 2005 Report Share Posted August 24, 2005 Hi all,I m trying to integrate Labview 7.0 (on Mandrake linux) to mysql 4.1 using C APIs. I use the labview utility - lvmkmf i.e lvmkmf my_conn (my_conn is the C program that uses the mysql C APIs) The C APIs require the library mysqlclient and I have included it in the Makefile using the CINLIB macro. And I get the following error. gcc -shared -o my_conn.tmp \ /home/viji/cintools/cin.o my_conn.o /home/viji/cintools/libcin.a /home/viji/cintools/libmysqlclient.a /home/viji/cintools/lvsbutil -c my_conn -t CIN -d `pwd` /home/viji/cintools/my_conn.tmp: undefined symbol: compress /home/viji/cintools/lvsbutil: error building resource file: 1 make: *** [my_conn.lsb] Error 2 Is the lvsbutil trying the compress the libraries and giving an error when trying to do so? Thanks, Viji 5718[/snapback] There is an example here showing how to call the mysql C API. I'm not sure about your error (sorry), but maybe this example will provide some insight. I was able to get it to work on my Linux box. -Jim Quote Link to comment
Mike Ashe Posted November 9, 2005 Report Share Posted November 9, 2005 Anyone done this using MySQL under Windows and then made wrappers for both to make the upper level platform independent? Quote Link to comment
LuI Posted November 9, 2005 Report Share Posted November 9, 2005 Anyone done this using MySQL under Windows and then made wrappers for both to make the upper level platform independent? Mike, don't know about the way this was done, but Anthony Lukindo from Advanced Measurements Inc. published a solution java script:emoticon(':thumbup:', 'smid_27') smilie that acts as you asked for in LTR: "Simplified LabVIEW Database Access: A Single VI Solution for Connecting, Reading and Writing to Your Database" by Anthony Lukindo in LabVIEW Technical Resource, Volume 12, Number 3. As you probably know, LTR is gone now. I'd suggest contacting Anthony for this VI. If this does not work I could provide a wrapper around his VI that checks a global value to switch DB access on or off. Quote Link to comment
