widget, automator and spotlight
  • 4 weeks later...
  • 2 months later...
I found this on ni.com (see atachment), but I'm not able to use the widget. I obtain "unable to locate VI" message with all config I Tried :(
I finally succeeded in making it work
- enable the Web Server (Option menu -> Web Server : configuration)
- in the widget, fill the ip address and the number of port choosen
- don't try to see a VI which don't have a ".vi" extension ! (or modify the widget code to delete this automatic addition ... it is really easy)
