Call Library Function -> PID
os: Debian
I've written a c Function and compiled it to a shared object. I call the function in labview and it executes just fine. The function modifies a ".cti" file. When I want to execute the function a second time it fails because labview still takes ownership of the process even after it terminates. When I run the function without labview this error doesn't occur..
This is my function:
extern "C"{
    int InitSDK();
int InitSDK()
    string ctiPath;
    string genicamPath;
    string genicamCachePath;
    string clProtocolPath;
#if defined (WIN32)
    char buffer[1024] = { 0 };
    int res = GetEnvironmentVariableA("GENICAM_GENTL64_PATH", buffer, sizeof(buffer));
    if (0 == res)
        return false;
    ctiPath = string(buffer);
    memset(buffer, 0, sizeof(buffer));
    res = GetEnvironmentVariableA("SVS_GENICAM_ROOT", buffer, sizeof(buffer));
    if (0 == res)
        return false;
    genicamPath = string(buffer);
    res = GetEnvironmentVariableA("SVS_GENICAM_CACHE", buffer, sizeof(buffer));
    if (0 == res)
        return false;
    genicamCachePath = string(buffer);
    res = GetEnvironmentVariableA("SVS_GENICAM_CLPROTOCOL", buffer, sizeof(buffer));
    if (0 == res)
        return false;
    clProtocolPath = string(buffer);
    SV_RETURN ret = SVLibInit(ctiPath.c_str(), genicamPath.c_str(), genicamCachePath.c_str(), clProtocolPath.c_str());
#elif defined(__linux__)
    ctiPath ="./";
    SV_RETURN ret = SVLibInit(ctiPath.c_str(), NULL, NULL, NULL);
#elif defined(__APPLE__) && defined(__MACH__)
    ctiPath = "/Library/Frameworks/SVGenSDK.framework/Versions/2.5.8/Libraries/cti";
#endif
    if (SV_ERROR_SUCCESS != ret)
        printf("SVLibInit Failed! :%d", ret);
        return -1;
    printf("Init worked \n");
    return 0;
  • 1 month later...
Your problem likely is that SVLibInit() opens a handle to your file(s) and you never release them. Windows (Linux too) will clean up unclosed handles/fileids when a process exits but not before that.
So you should also have a function SVLibUninit() or similar that will then release all the resources, and of course call it from LabVIEW when you are done with your software. Once that happens, you can access those files from other processes too, without needing to close LabVIEW.
Edited by Rolf Kalbermatter
