1 Posted April 21, 2023 Report Share Posted April 21, 2023 I need to be able to set the array "ingredients" to search on max 5 rows of the ingredients entered by the user referring to the array "All". then return the array row that contains at least 1 of the words in the array "Set using all specified ingredients" there must be no repetition of rows. I have been working on it for several days but I have no idea how to extend the array to more rows. Basically when you write a word that is in the array "Set using all specified ingredients" below the 5th line nothing appears on the array below it same exact thing for the array "ingredients" where you cannot write beyond 2 lines. any ideas ? can you help me? Find Recipes.vi Link to comment
mcduff Posted April 21, 2023 Report Share Posted April 21, 2023 You should link this to the original discussion on the darkside, https://forums.ni.com/t5/LabVIEW/Help-issues-with-arrays/m-p/4299181 There you marked the VI by Altenbach you posted here as the solution to your problem. What array do you want to extend? Your question isn't clear to me. Maybe some of the learning resources at NI would help? Link to comment
Please sign in to comment
Sign In Now
