Arithmetic is different in formula nodes
jpdrolet
That must be very old but anyway...
For example, the result of arithmetic operations on uInt8 are coerced to 0-255.
5-10 gives 0
250+10 gives 255
Edit: This is alos true for expression nodes
That is a quite different implementation than the arithmetic nodes, where the results are modulo 255.
5-10 gives 251
250+10 gives 4
Interesting to note, thank you. I also came across another interesting deviance. TheĀ  Formula Parsing requires ^ for exponent while the Formula Node requires **.
I was trying to be able to read in formulas from files into the formula nodes but it doesn't seem to have a way. Does anyone know of one, or do I have to continue using Eval?
5953[/snapback]
Formula nodes can only be modified at edit time. Use Eval.
And the original post also holds for expression nodes.
5953[/snapback]
This is a bug. Originaly (pre-LV6i), the formula node used ^ for exponent. I think in LabVIEW 6i they changed the exponent to ** for the formula node. They forgot to change the Eval node. See attached image of the formula node online help for LabVIEW 51 showing the exponent notation used.
post-2-1125628486.png?width=400
