epiz Posted July 13, 2023 Report Posted July 13, 2023 (edited) I have a combo box where once I select an item its value is then placed in a string I created. I am writing all the values in normal(text) display. The string then displays all of these normal values in hex form. Here is my problem: For only some of these values there are a 1-2 bytes of info that aren't exactly how I want it. For example, the hex string 000D in normal is a blank. I am having trouble portraying what is a blank. I can't just put a space because it either writes as a 20 or just slides all my data over. If a better explanation or picture is needed let me know. Any help is appreciated thank you I just did my own string conversion and copied and pasted the blank value and it worked, but if there is a better way to do it let me know Edited July 13, 2023 by epiz Quote
