klessm1 Posted September 9, 2005 Report Posted September 9, 2005 Does anyone know of a way to perform a file drag and drop with multiple files from windows explorer to a LabVIEW treeview? It is so easy in .NET, but LabVIEW seems ignore this function. They have a file drag and drop for path controls. I heard that the next version of LabVIEW allows .NET controls which support file drag and drop, but I know there has to be some way in windows to enable the drop event for the control and get the file drop data into a LabVIEW treeview. Thanks for any help. Quote
Michael Aivaliotis Posted September 12, 2005 Report Posted September 12, 2005 See here and here for some ideas. Quote
klessm1 Posted September 12, 2005 Author Report Posted September 12, 2005 See here and here for some ideas. 6105[/snapback] I had tried the transparent control right after I sent out this question. The main issue I had with the transparent control approach is that I couldn't find a way to drop multiple files into the control. I belive the drag and drop event for the control looks to see if there are multiple files and doesn't allow a drop. This makes perfect sense because you can only hold one value in a path control. You can drop a folder which will allow you to get all of the files under that folder. So I guess that is some consolation. Thanks for your help Quote
