alphaone Posted September 13, 2005 Report Posted September 13, 2005 Use "Set Color" tool ,table bk color can not be changed,but sometime can! It's determined by the position of mouse in the "color select panel". It happens not frequently,but it exists! if i wanna change the table bk color,only method is programming ,why Labview didn't process this like CVI easily? Quote
Michael Aivaliotis Posted September 13, 2005 Report Posted September 13, 2005 This does not seem to be a problem in the "classic" version of the table. I assume you are using the default 3D one. This is probably a bug but there is a workaround that "unlocks" the colour picking on the background. See the attached AVI that shows the solution. Download File:post-2-1126592671.zip As you can see, the background colour selection "unlocks" once you hover over the first (far left) user defined colour. Quote
alphaone Posted September 13, 2005 Author Report Posted September 13, 2005 This does not seem to be a problem in the "classic" version of the table. I assume you are using the default 3D one. This is probably a bug but there is a workaround that "unlocks" the colour picking on the background. See the attached AVI that shows the solution. Download File:post-2-1126592671.zipAs you can see, the background colour selection "unlocks" once you hover over the first (far left) user defined colour. 6120[/snapback] :thumbup: Yes!that's it! Thank you very much. i found that the mouse must move to the right end of "T" bar,i think maybe you must chose the 100% transparent. Quote
