gyali12 Posted October 25, 2023 Report Posted October 25, 2023 Hi team, I am in search of DS2484evkit LabVIEW driver. Kindly help me to get it. thanks, Gyali12. Quote
smarlow Posted October 25, 2023 Report Posted October 25, 2023 That kit uses a DS9400 USB/I2C adapter as an interface. According to DigiKey, that device is no longer made, so you are probably going to have a hard time finding any drivers for it. The DS2484evkit has some software you can download from Analog. The last listed compatible OS is Windows 8. That package probably has a DLL Driver for the DS900, but you'll probably have to write your own LabVIEW wrapper, unless you can find one here. If you just want to connect a 1-wire network to USB, you can use an Arduino. There is an Arduino library for operating a 1-wire network, and you can buy a 1-wire shield from DigiKey (part# MAXREFDES132#-ND). That Arduino shield has the same DS2484 chip (and RJ connector) as the DS2484evkit, so you can use the Arduino I2C bus to read and write data to the 1-wire bus, and use the Arduino serial interface for the PC. You can also select a jumper to run it in "bit-bang" mode using the Arduino GPIO instead of the DS2484 chip. I have used this Arduino setup in bit-bang mode and it works extremely well. You'll have do a little bit of programming on the Arduino to implement a serial command to scan the 1-wire bus and return the data (there is a bunch of example code). But you can make up your own data format (such as CSV ASCII). The programming on the LabVIEW side to read the Arduino is a simple VISA serial connection. I think I would go this direction, since the DS900 device is obsolete. Quote
