Fernandotid Posted September 15, 2005 Report Posted September 15, 2005 Hello. I would like to ask you a question. I've seen that it is possible to open and to write arrays and tables into an excel file and show it from labview using ActiveX. Is it possible to make something like that wiht Microsoft word? I mean, I want to write some strings into a word document using active x but I don't know how to do it because I'm new using activeX controls. Thank you very much. :headbang: Quote
Mikrobi Posted September 15, 2005 Report Posted September 15, 2005 Hello.I would like to ask you a question. I've seen that it is possible to open and to write arrays and tables into an excel file and show it from labview using ActiveX. Is it possible to make something like that wiht Microsoft word? I mean, I want to write some strings into a word document using active x but I don't know how to do it because I'm new using activeX controls. 1.Get ActiveX container (Front Panel >> Containers>> ActiveX Container) 2. RMB(mouse menu)>> Insert ActiveX Object 3. Select at the top:'Create Document' >> at list: Microsoft Word Document On the diagram: 4. Functions>>Communication>> ActiveX>> 5. Terminal 'Document' >wire>Automation Open function >> Property Node and Invoke Node gets you lots of fun best regards Mikrobi Quote
peteski Posted September 15, 2005 Author Report Posted September 15, 2005 Hello.I would like to ask you a question. I've seen that it is possible to open and to write arrays and tables into an excel file and show it from labview using ActiveX. Is it possible to make something like that wiht Microsoft word? I mean, I want to write some strings into a word document using active x but I don't know how to do it because I'm new using activeX controls. Thank you very much. :headbang: Fernandotid, For some "built-in" examples of axtive-x control of Excel, go to "Find Examples" from the startup Dialog: Then navigate through the hierarchy to come to the following examples: Good luck! -Pete Liiva Quote
Mike Ashe Posted November 9, 2005 Report Posted November 9, 2005 Search on NI DevZone, there is an example that does what you want and includes a library of VIs to use ACtiveX to make a small report in Word, including tables, etc. Creating a Report in Word ... Play around with the methods and property nodes, kyou will find that there is very little you cannot do by modifying this. Quote
