Helios 74 Posted September 16, 2005 Report Posted September 16, 2005 Hi, I'm interesting in DSC module for a my remote monitoring application. The system receive the data from a lan connection by PXI - 8231. This device has not OPC Server. In which way can i connect TAG Engine to ethernert device bit stream !? Regards Elio Quote
Khalid Posted September 17, 2005 Report Posted September 17, 2005 Hi, How are you acquiring the data on the PXI? If it's DAQ data, you could use DAQ-OPC. Regards, -Khalid Quote
Helios 74 Posted September 19, 2005 Author Report Posted September 19, 2005 Hi,How are you acquiring the data on the PXI? If it's DAQ data, you could use DAQ-OPC. Regards, -Khalid I'm acquiring the data from PXI RT Controller - 8132 Ethernert board. What about you ?! I'm acquiring the data from PXI RT Controller - 8132 Ethernert board. What about you ?! Quote
Khalid Posted September 20, 2005 Report Posted September 20, 2005 You will have to send the data from the PXI to DSC box via TCP or DataSocket. And then use Memory Tags on DSC. Hope this helps. -Khalid Quote
