How to modify Build specifications with property node ?
Hi everyone,
I would like modify a project build specification by using input only the path of the Lvproj.
Is it possible ?
I would like to change with a VI a destination directory of a Build Specification
Thank you for your help
There is an App Builder API which will allow you to accomplish this task, but it is not officially supported by NI. The VIs are in [LabVIEW 20xx]\vi.lib\AppBuilder\AB_API, and there is an examples subfolder there with a few examples that should help you get started.
  • Like 2
