Front Panel function and Error
Welcome to LavaG.
This is a queue: What Is a Queue in LabVIEW? - NI
You probably tried to delete the control inside the queue indicator. This does not work because a queue must always have a subtype. As the error message suggests, simply drag a new type on the queue indicator and it will replace the existing one.
Alternatively, use the 'Obtain Queue' function on your block diagram to create a new indicator based on the configured input type.
