Input Flip Function
Now that I've learned about <ctrl> when wiring to flip 2-input functions, I use it a lot. :thumbup:
Just about everything, including quotient and remainder, recognizes this but the Data Selector has been missed.
I think it could benefit from it.
Thanks,
Barrie
  • 2 months later...
I'm missing something simple here, I tried this just now with 7.3 and it doesn't work for me. I'm sure its a simple mistake. How about a two line Flip for Dummies recipe.
1st line - wire up a 2 input function (add, multiply, AND...).
2nd line - hold down ctrl and hover over the inputs. The cursor will change to allow you to "flip" or reverse the inputs.
The thing is it doesn't work with the select function (which is actually a three input function, but it would be nice if the T and F inputs could be flipped). One other nice thing about the select function is that you can wire an error wire into it as the selector, the same as you would do with a case structure.
