It seems like remote debugging will work similer to RT debugging...
Yep it is a very similar experience. Check a box in App Builder, build your app, run it, then in LabVIEW go to Operate>Debug Application or Shared Library to connect to the app. And of course the app can just be on your local machine. If you are in the Beta program you can check it out now before you get your final copy.
Kennon
