malef Posted November 2, 2005 Report Posted November 2, 2005 Problem: Writing to the cursor position property does not update the position shown in the cursor legend. What can I do to update the cursor legend? Solution: There is a known issue which causes the cursor legend to not update properly when writing to the Cursor->Cursor Position->Cursor X and Cursor->Cursor Position->Cursor Y properties. As a workaround, to update the legend you can run the VI again or write to the property node twice by putting it in a for loop that executes twice. Alternatively, you can use the Cursor List property to programmatically change the cursor's position. Manfred Quote
