dimes1827 Posted November 3, 2005 Report Share Posted November 3, 2005 Help needed pls.. how do we access network passwords with labview?? because when a network server has a password requiremnt, like these, i cant use the FILE vi's like the LIST,NEW etc.. what do i need to do to pre-program the network access? thanks! Link to comment
Jim Kring Posted November 3, 2005 Report Share Posted November 3, 2005 Help needed pls..how do we access network passwords with labview?? because when a network server has a password requiremnt, like these, i cant use the FILE vi's like the LIST,NEW etc.. what do i need to do to pre-program the network access? thanks! You can use the NET USE command, using System Exec to execute the command line. C:\WINDOWS\system32>net use /? The syntax of this command is: NET USE [devicename | *][\\computername\sharename[\volume] [password | *]] [/uSER:[domainname\]username] [/uSER:[dotted domain name\]username] [/uSER:[username@dotted domain name] [/sMARTCARD] [/sAVECRED] [[/DELETE] | [/PERSISTENT:{YES | NO}]] NET USE {devicename | *} [password | *] /HOME NET USE [/PERSISTENT:{YES | NO}] Link to comment
dimes1827 Posted November 3, 2005 Author Report Share Posted November 3, 2005 You can use the NET USE command, using System Exec to execute the command line. Thanks! i did it.. like this n the command line of system Exec NET USE \\COMPUTERNAME /USER:DOMAINNAME\USERNAME then iterated the system exec with the Password input text to its commandline Link to comment
Jim Kring Posted November 4, 2005 Report Share Posted November 4, 2005 Thanks! i did it.. like this n the command line of system ExecNET USE \\COMPUTERNAME /USER:DOMAINNAME\USERNAME then iterated the system exec with the Password input text to its commandline Great :thumbup: Link to comment
Please sign in to comment
Sign In Now
