Some other color than NI blue?
WMassey
For a listbox control/indicator is it possible to specify the color used to highlight the selected item(s)?
You can do it, but it's an OS setting, even if you use the standard listbox, and as such will affect the rest of your OS. Look at Michael's post here for the exact method.
Ahh. I feared as much. I was hoping to be able to change just one listbox out of several to make it stand out but if it is a windows-wide setting then that won't work.
Thanks for the reply though!
You could use a Multicolumn Listbox.
Actually that is what I am using and in this respect a multicolumn listbox and an ordinary listbox behave exactly the same -- you select a line and the entire line is highlighted by a color that is apparently dictated by a system-wide setting.
It was that specific color I was hoping to change in one particular case.
It's not going to happen.
Not true for multicolumn listbox. You can set the selection color. See the attached VI.
Son-of-a-gun, you are right! That's exactly what I needed. Thanks!
  • 1 month later...
