lgk Posted November 14, 2005 Report Posted November 14, 2005 Error appears after building the VI ,Multi-Panel Front Panel using Splitter Bars.vi which is built-in LV8 examples.The VI runs correctly in LV8 while the error occurs after building exe. When I press the button stop after maximizing the front panel it occurs. If not maximized the front panel the error will not and it runs correctly. The error message is below: Fatal Internal Error:"image.cpp",line 12727 LabVIEW version 8.0 You will lose any unsaved work.For assistance in resolving this problem,please relaunch LabVIEW,or contact National Instruments. Thanks. Quote
lgk Posted November 16, 2005 Author Report Posted November 16, 2005 Error appears after building the VI ,Multi-Panel Front Panel using Splitter Bars.vi which is built-in LV8 examples.The VI runs correctly in LV8 while the error occurs after building exe.When I press the button stop after maximizing the front panel it occurs. If not maximized the front panel the error will not and it runs correctly. The error message is below: Fatal Internal Error:"image.cpp",line 12727 LabVIEW version 8.0 You will lose any unsaved work.For assistance in resolving this problem,please relaunch LabVIEW,or contact National Instruments. Thanks. Have other somebody the same question? I really want to know the answer! Quote
