write: Labview-->OPC-->PLC
I am assuming you're using DataSocket Read VIs. So, to write to the OPC Server, you will use the DataSocket Write function (or VI if using the legacy version).
-Khalid
PS: You attached a VI; doesn't seem to do much. What was the purpose?
Sorry about that: just realized that you're using front-panel datasocket. So to write this way, you will want to make a "Publish" data-connection from your Control. Or if it's an Indicator then "Publish and Subscribe."
Unless it's a real simple project, you will have more flexibility using the DataSocket VIs as opposed (or, in addition to) to front-panel datasocket only.
-Khalid
