diodo Posted November 22, 2005 Report Posted November 22, 2005 I tried to generate a finite pulse train with my DAQCard-700 using the "Finite Pulse Train (8253).vi" example, but there's not response. The VI runs correctly but there isn't any pulse at OUT2 Counter pin (I made the right external link between the counters, and the signal at CLK2 and GATE2 pins are correctly, and I'm sure Counter 2 isn't broken). Can you help me? I use LabVIEW 5.1 version Thank you Quote
AnalogKid2DigitalMan Posted November 22, 2005 Report Posted November 22, 2005 Diodo: How are you verifying that the pulses are not there? Quote
diodo Posted November 23, 2005 Author Report Posted November 23, 2005 I try with a scope and even with the NITestPanel, a software included with the board. Quote
AnalogKid2DigitalMan Posted November 23, 2005 Report Posted November 23, 2005 Have you tested your 7404 inverter chip? I see the connection diagram on the front panel of the example does not show power being supplied to the 7404. So if you made all connections like it shows, you would still be missing two. Connect +5VDC to pin 14 (Vcc) on the 7404 and Ground to pin 7 (Gnd) on the 7404. You can get 5V and Gnd right off of the DAQ card. Hope this helps and if you already have 5V and Gnd going to the 7404 then I do not know what else could be awry :headbang: Quote
diodo Posted November 24, 2005 Author Report Posted November 24, 2005 In DAQCard-700 the timer chip is 8254 (not 8253) so the inverter chip is integrated (there's a OUT1* pin, that is the OUT1 pin inverted). Quote
