luke Posted November 25, 2005 Report Posted November 25, 2005 I heared about the possibility to use LV controls (such as graphs) in other languages (such as Visual Basic) using ActiveX (without using Measurement Studio) Do anybody know how can I do that? Thanks Quote
Rolf Kalbermatter Posted November 27, 2005 Report Posted November 27, 2005 I heared about the possibility to use LV controls (such as graphs) in other languages (such as Visual Basic) using ActiveX (without using Measurement Studio)Do anybody know how can I do that? Thanks This can't work as you describe it. LabVIEW controls are almost all implemented in a LabVIEW native format and can't be accessed through ActiveX. You can however buy ComponentWorks from NI which supports similar control elements than what you have in LabVIEW. Another option is to put your VIs with the Application Builder into a DLL and call them as functions in your other language. This will however still display the entire front panel as a separate window and not as a control on the window surface of your foreign application. Rolf Kalbermatter Quote
