alphaone Posted December 8, 2005 Report Posted December 8, 2005 Hi, I input a "Numeric" with Unit of "Hz", and output to a "Numeric indicator",the fatal error happened when running. Check the following figures. And I want use the Numeric control with Unit input into the "Formular Node", but it can't do! Using the Unit would be couraged?? Download File:post-2988-1134008598.vi Quote
didierj Posted December 8, 2005 Report Posted December 8, 2005 What a strange example... On my computer, when I start this vi, it never stops and raises the cpu load to 100%. In the meantime I read the whole Info-LV-digest, and now while I write this post the vi is still running and my cpu tells 100% load. Most strange is although the cpu load is at 100%, I don't seem to have any limitation in speed for the other apps. ... I think I'll have to kill this LV-session... ...Update: after 25(!!!) Minutes I finally also got your error. :thumbdown: Quote
alphaone Posted December 8, 2005 Author Report Posted December 8, 2005 didierj said: What a strange example...On my computer, when I start this vi, it never stops and raises the cpu load to 100%. In the meantime I read the whole Info-LV-digest, and now while I write this post the vi is still running and my cpu tells 100% load. Most strange is although the cpu load is at 100%, I don't seem to have any limitation in speed for the other apps. ... I think I'll have to kill this LV-session... ...Update: after 25(!!!) Minutes I finally also got your error. :thumbdown: Maybe, this is a solution that use "Type Case" to transfered. Download File:post-2988-1134030669.vi Download File:post-2988-1134030858.vi Download File:post-2988-1134030911.vi Quote
DredPirate Posted December 8, 2005 Report Posted December 8, 2005 And here is another reason not to use express VIs or LV unit labels. Had to kill LV to stop this VI. Quote
