fei Posted December 15, 2005 Report Share Posted December 15, 2005 Hi everyone: I am new with LabVIEW. This is the first project I am doing. I want to use Labview as a Hyper Terminal, I found one VI is very close to what I need, But the message read window does not keep the current data, I have to use a scroll bar to read the current data. Is a way or some setting to keep the message window show the last 10 lines or the current data (like Hyper terminal). Thanks I am using Ladview 7.0 Download File:post-3710-1134683990.vi Quote Link to comment
Neville D Posted December 15, 2005 Report Share Posted December 15, 2005 Hi everyone:I am new with LabVIEW. This is the first project I am doing. I want to use Labview as a Hyper Terminal, I found one VI is very close to what I need, But the message read window does not keep the current data, I have to use a scroll bar to read the current data. Is a way or some setting to keep the message window show the last 10 lines or the current data (like Hyper terminal). Thanks I am using Ladview 7.0 Hi Fei, Remove the shift register which is used to collect all the message strings and append the new ones to the old list. See attached image: Neville. Quote Link to comment
fei Posted December 16, 2005 Author Report Share Posted December 16, 2005 Hi Fei,Remove the shift register which is used to collect all the message strings and append the new ones to the old list. See attached image: Neville. Hi Neville; I removed the shift register like you said, but it only showing one line, before I removed the register, it shows all the data lines. is a setting for number of lines showing? Thank you Quote Link to comment
