zli0022 Posted December 18, 2005 Report Posted December 18, 2005 Hi! Guys, My name is Ross Liu. I would like to share a little problem with Labview. I have a VI with a cluster used for real measuring data display. I need a cluster size to be changable because I used different configration file with different channels. I would like to know if it is possible to change the cluster size with diffent number of channels data display. I am still using LabVIEW 6.1. Or is there any better way to deal with this case? Many Thanks!! Ross Liu :headbang: :headbang: :headbang: Quote
didierj Posted December 19, 2005 Report Posted December 19, 2005 Depending on which purpose you want to show/hide elements in the cluster I see 2 possibilities: 1. If you just need show/hide for cosmetic purposes, get the control refs from your cluster and show/hide the elements. The order of the elements you get with "all controls"-property is the order you placed them into the cluster. 2. If you use the cluster to read/write configfiles (with e.g. openG) then you'll have to build as many clusters as you have possibilities and show/hide only one of them. In the background you'll have to deal which cluster you pass to the inifile. In LV6 I used some ActiveX-tab control to change between configs Didier. Quote
Mike Ashe Posted December 19, 2005 Report Posted December 19, 2005 You might want to consider backing up a step and basing your configuration setup and files on arrays of clusters. You also should look at the OpenG Variant Data and Variant Config File VI sets. Quote
zli0022 Posted December 19, 2005 Author Report Posted December 19, 2005 Guys, Thank you very much for your reply. The reason I need variable cluster size (for displaying measuring data) is that there are so many different kind of tests in our lab with different number of channels. I try to design my code (using cluster for dsiplaying the data) to as flexible as possible to include all different case. I will also look at Open G to get better solution. Thank you so much for your help!! Ross Liu Quote
