Droopy Posted January 29, 2006 Report Posted January 29, 2006 Ive been doing those like example things on LabVIEW and ive gotten to one and it tells me half way through that i dont have the devices for the Voltage that I am trying to measure. Will i have to wait till my robot is built for that, or is there something else i need to get with LabVIEW. thanks Quote
nudalakasim Posted January 29, 2006 Report Posted January 29, 2006 Ive been doing those like example things on LabVIEW and ive gotten to one and it tells me half way through that i dont have the devices for the Voltage that I am trying to measure. Will i have to wait till my robot is built for that, or is there something else i need to get with LabVIEW.thanks Droopy, To measure voltage you require a card( or device), no doubt, but to run the program without errors, you can use simulated devices, which you can create using NI-MAX. See attached image. Here I assumed that you are using DAQmx...if not this cannot be done..You probably have to wait till you get your Robot(device?) is ready . nudalAKasiM Quote
AnalogKid2DigitalMan Posted January 30, 2006 Report Posted January 30, 2006 Starting with DAQ 7.5, simulated hardware devices can be configured in MAX so that you can proceed with software development wihtout a card. You may want to look into this. Quote
