rkehn Posted January 29, 2006 Report Posted January 29, 2006 I am using LabView 6.1 on a project and would like to scan the cards installed in the SCXI chassis. Then finally I would load the appropriate drivers(My VIs) at startup. What I currently know: [*] There is a sub VI that will return the cards that are installed but only if you have set them up in MAX first. [*] Looks as though I can add and remove cards with VI Quote
Rolf Kalbermatter Posted February 2, 2006 Report Posted February 2, 2006 I am using LabView 6.1 on a project and would like to scan the cards installed in the SCXI chassis. Then finally I would load the appropriate drivers(My VIs) at startup. What I currently know: [*] There is a sub VI that will return the cards that are installed but only if you have set them up in MAX first. [*] Looks as though I can add and remove cards with VI Quote
