VI-Hunter Posted February 13, 2006 Report Posted February 13, 2006 Hi everybody! I've a problem with calling Windows API: I need to work with Active Directories on Windows Server 2003. On start I want to login with the LogonUser function of the advapi32.dll. I tried to call the function via LV dll-call without success (I use LV 7.1). After this I wrote an CIN for this. But it don't makes me happy. I alwas get an error (not enough space). I'm confess that my C is not 100% good, but it's sufficed up to now. Jens Download File:post-3936-1139819885.zip Quote
Rolf Kalbermatter Posted February 15, 2006 Report Posted February 15, 2006 Hi everybody!I've a problem with calling Windows API: I need to work with Active Directories on Windows Server 2003. On start I want to login with the LogonUser function of the advapi32.dll. I tried to call the function via LV dll-call without success (I use LV 7.1). After this I wrote an CIN for this. But it don't makes me happy. I alwas get an error (not enough space). I'm confess that my C is not 100% good, but it's sufficed up to now. Jens First: GetIndirectFunctionHandle and friends were only meant and available for LabVIEW for Windows 3.1. Second: In order to call a function over a pointer variable, this pointer variable must be properly typed either through the declaration itself or a typecast at the point of call. Otherwise the C compiler can't know how to pass the parameters and what to expect as return value. if (!(UsernameCStr == (char *)DSNewPtr(*Username)+1)) {cinErr = mFullErr; goto out; } will allocate not what you think it does. It will use the pointer value in the handle as length indicator and attempt to allocate potentially a huge amount of memory running out of memory quite soon. You should make this read if (!(UsernameCStr == (char *)DSNewPtr(LStrLen(*Username))+1)) {cinErr = mFullErr; goto out; } and even better would be to allocate a cleared memory area with DSNewPClr(). Instead configuring a CallLibraryNode with advapi32.dll, LogonUserA, stdcall calling convention, the string parameters as C string pointers and the two constants as uInt32 and the last one as an uInt32 passed as pointer, simply should work fine. Last but not least you will leak a handle here with LogonUser returning the phToken that never gets closed. Rolf Kalbermatter Download File:post-349-1140011772.vi Quote
VI-Hunter Posted February 16, 2006 Author Report Posted February 16, 2006 You should make this read if (!(UsernameCStr == (char *)DSNewPtr(LStrLen(*Username))+1)) {cinErr = mFullErr; goto out; } and even better would be to allocate a cleared memory area with DSNewPClr(). Thank you. I modified the the command to if (!(UsernameCStr = (char *)DSNewPClr(LStrLen(*Username)+1))) {cinErr = mFullErr; goto out; } and the memory error is gone. Instead configuring a CallLibraryNode with advapi32.dll, LogonUserA, stdcall calling convention, the string parameters as C string pointers and the two constants as uInt32 and the last one as an uInt32 passed as pointer, simply should work fine.Yes, it's working. Last but not least you will leak a handle here with LogonUser returning the phToken that never gets closed.Rolf Kalbermatter You are right, I can't close the handle. I tried a CallLibraryNode with kernel32.dll/CloseHandle but I get an error. So I included the line CloseHandle(*phToken); after the function call LogonUserA(..) in the CIN and it's working without error. This means I need to include my ActiveDirectory between these commands. But this is my next step. Jens Quote
Rolf Kalbermatter Posted February 16, 2006 Report Posted February 16, 2006 You are right, I can't close the handle. I tried a CallLibraryNode with kernel32.dll/CloseHandle but I get an error. So I included the line You probably tried to do some fancy datatype here. Just treat the handle as uInt32. In the Logon function this parameter is passed as Pointer to Value. In the CloseHandle case just as Value only since it is not a parameter by reference here. Rolf Kalbermatter Quote
