jenny Posted February 16, 2006 Report Posted February 16, 2006 hi, i'm a student and new to Labview. i'm facing some problem here. i'm using "Equal" to compare 2 value, so the it return 2D-array of boolean. i need to connect it to a boolean to show both value is equal. so what should i do? anyone has any idea? what should i do to connect "Equal" to boolean (boolean is a LED in Front Plane)?? thank you! Quote
orko Posted February 16, 2006 Report Posted February 16, 2006 hi, i'm a student and new to Labview. i'm facing some problem here. i'm using "Equal" to compare 2 value, so the it return 2D-array of boolean. i need to connect it to a boolean to show both value is equal. so what should i do? anyone has any idea? what should i do to connect "Equal" to boolean (boolean is a LED in Front Plane)?? thank you! Jenny, It would help if we had a little more information. What are the values you are comparing? Are you using the blue Express "Comparison" VI or the little yellow triangle "=" operator? I'm assuming since you are getting a 2D boolean array out of it that you are comparing two 2-D boolean arrays? Thanks for clarifying, Joe (orko) Quote
Louis Manfredi Posted February 16, 2006 Report Posted February 16, 2006 Hi Jenny: Welcome to LabView. Not totally sure I understand your question, but if I do, selecting "Compare Agregates" from the right-click pop-up for the equality function might do the trick :question: Hope this helps, Best Regards, Louis Quote
jenny Posted February 18, 2006 Author Report Posted February 18, 2006 hi. orko. yes, i'm comparing 2D array boolean. i'm using yellow triangle "=". hi, Louis. thanks. i will try. Quote
i2dx Posted February 18, 2006 Report Posted February 18, 2006 jenny, I don't understand exactly what's the problem is, but i have attatched a vi, which shows some operations on boolean arrays. Please take a look at them and let me know wether they were helpfull or not ... CB Download File:post-885-1140248788.zip Quote
orko Posted February 19, 2006 Report Posted February 19, 2006 hi. orko. yes, i'm comparing 2D array boolean. i'm using yellow triangle "=". hi, Louis. thanks. i will try. Ah. Well if all you want to do is compare two arrays (any dimension) and get a "yes/no" if they are equal or not is to do as Louis suggested. Quote
