Trying to connect two inputs into a visa write block
oxygen
Hello everyone this is my first post here so I was unsure where to post this problem I have.
Basically I have attached the file i am working on, I am stuck trying to remove the faulty connection I have. I am trying to create an initialize button (bottom part of attachment) but am unsure how to go about doing this, the attachment shows how far I have progressed.
Is it possible to input two different strings into the visa write box? Is it possible to create the initialize button any other way?
I will be very grateful for any suggestions on how to solve the problem
Thanks
Download File:post-4193-1140443014.vi
Thanks
just wanted to say i have managed to solve this problem....but have encountered another problem I could do help with!
I have attached the file solving the problem I had before. Basically the problem now is with the received message from the serial port. I am communicating with a stepper mottor and sometimes when i click on the initialize button i receive a message along the lines "00#0000110001". The problem is how do i automatically reset the values from 1 to 0 without using a reset button. The 00 before the hash button are constant and do not need to be altered. It is also not always the case that 1's are appearing.
Once again I will be grateful for any help received, Thanks in advance :thumbup:
Download File:post-4193-1140449811.vi
