I need help!
Hi guys:
I have two problems when I build my executable:
1. I have lv8.0 and i make one application with database toolkit, bit when i run my exe the vis of database toolkit, i have continued with all the recommendations like the manual of database toolkit chap. 6 and don't work, how can I make so it works?
2. I am using crystal reports for my reports, how can I include the files .rpt with my exe and installers?
Thanks very much
Julio
Thanks Dido for your help,
regarding the first question I should explain that my problem is when i build my installer, and I use the vis of the database toolkit .When I install my application all works fine with exception for those task that executes the vis of database toolkit. I have followed the recommendations of NI and that contained in the manual of database toolkit, chap. 6. without positive results.
With regard to the second question, besides includes the files rpt, I should include some installer od Crystal Reprots? if it is the way, how can I obtain it?
Thanks in advance
Julio
