Changed VI Error List Behaviour
The behaviour in the VI Error List has changed in LV 8.0 compared to 711 and ALL prior releases.
In LV711 the errors in the VI's were sorted reverse hierarchically. This means if you had a broken VI at the very bottom of your hierarchy, you could scroll to the top of the list and doubleclick on the error which would bring you to the broken VI. If you fixed this one VI you would have fixed ALL your errors since this one VI error was essentially propogated. Sorting the VI errors in this fashion helps find and isolate problems FAST!
In LV8.0, I have no Idea what the order is. I know there is an order, but who does this order serve?
See the attached images reproducing the same error in both LV versions.
LV711
post-2-1142277633.png?width=400
LV801
post-2-1142277676.png?width=400
It seems that this Version 8.0 is meant to please the advanced LV developers but it seems to be pissing us off more and more...
In LV711 the errors in the VI's were sorted reverse hierarchically... In LV8.0, I have no Idea what the order is. I know there is an order, but who does this order serve?
Well that's just damn annoying. :angry:
