Ton Plomp Posted March 27, 2006 Report Posted March 27, 2006 Hello All, I'm trying to store some info in a control in a VI. But I don't want to risk the 'Reintialize values to default'. So i was digging the control methods to make the current value default. I can't find it, the only 'Make current values default' item is located in the VI-class were ALL controls are saved So is this possible? and which class should I use. Moreover, how te create a new control in LV8, in LV7 I used the get contorl [sIC] from type descriptor.. but this currently returns an array with the type descpriters in it...... :thumbdown: Ton Issue 1 solved: there is a PROPERTY Default Value.... Quote
