badwolf Posted March 27, 2006 Report Posted March 27, 2006 Hello all! I attached here my examples VIs. The first one (write.vi) is a "data producer". I need to compile it and run it (continuosly, there's a while loop aroound). This would be "write.exe". The other one, readshot.vi, hasn't a while loop around. This is a one shot VI. I need to transform in a DLL to be called from another programming language (Delphi) whenever I want. I try to compile them separately but....it doesn't work. I'm unable to read data from readshot. I'm using Labview 7.1.1. Badwolf Download File:post-1101-1143453355.vi Download File:post-1101-1143453430.vi Quote
Aitor Solar Posted March 27, 2006 Report Posted March 27, 2006 Notifiers (and queues, etc) don't work between different applications, like two exes. You'll have to use another way of sharing information, like ActiveX. Will LabVIEW Queues or Semaphores Work Between Executables? Saludos, Aitor Quote
