Is there a way to Prevent XP to Standby?
Hello,
I have a LabView application, that continuously acquires data. If the PC enters in a Standby mode, the acquisition is stopped by the system and an error is returned.
Is there a way directly from LabView, to prevent the system to enter in a Standby mode?
Thank you for your help!
I know the way by right clicking on the desktop, selecting "Settings", selecting tab "Screen Saver" and clicking the button "Energieverwaltung" (how was it in english :ninja: , don't remember). But this is done interactively.
If you were looking for an automated method, I'm sure there must be an API-call where you can get/set this property, make a seach in MSDN... good luck!
  • 3 weeks later...
The Win32 call SystemParametersInfo has stuff about the screen saver, power management and many other things...
http://msdn.microsoft.com/library/default....ametersinfo.asp
When I launch my monitoring VI, I extend the screen saver timeout using that call (I modified some spaghetti found on the NI boards for this purpose):
Download File:post-3022-1145046622.vi
Do you need to have administrator rights to change this setting?
