Darren Posted March 30, 2006 Report Posted March 30, 2006 It looks like a screen redraw issue...the clusters both contain the correct data...if you take another Windows app and drag its window over your VI front panel, then move it back, you'll see the cluster contains the correct data. This problem seems to be fixed in the next LabVIEW release. -D Quote
orko Posted March 30, 2006 Report Posted March 30, 2006 Along with the screen redraw mentioned by Darren, it also appears to go away when you take the Event Structure out. The attached code is identical to yours, without the event structure. Download File:post-3266-1143734396.vi This problem seems to be fixed in the next LabVIEW release. The next LabView release being 8.1? The problem is still there in 8.0.1, so I'm assuming you're beta testing Quote
Darren Posted March 30, 2006 Report Posted March 30, 2006 I work in LabVIEW R&D, so yes, you could say I'm "beta testing"... -D Quote
sbota Posted March 31, 2006 Author Report Posted March 31, 2006 Hi Darren, Thanks a lot for your feedback. It Quote
orko Posted March 31, 2006 Report Posted March 31, 2006 @ orko : the problem is still there, it Quote
Darren Posted March 31, 2006 Report Posted March 31, 2006 Sorry guys...even from my days in the AE department long, long ago, it was drilled into our heads never to talk about potential release dates for unreleased software. No points off for trying, though... -D Quote
AnalogKid2DigitalMan Posted April 4, 2006 Report Posted April 4, 2006 Odd, I activated 8.0 on a machine yesterday, it gave activation codes for LV PDS 8.0 AND LV PDS 8.1. The codes are different too. Quote
ad_dekkers Posted April 4, 2006 Report Posted April 4, 2006 Odd, I activated 8.0 on a machine yesterday, it gave activation codes for LV PDS 8.0 AND LV PDS 8.1. The codes are different too. I think i have a work around! Make the array of clusters invisible, update the data and make it visible again. Quote
