Array of clusters front panel update LV8.01
sbota
It looks like a screen redraw issue...the clusters both contain the correct data...if you take another Windows app and drag its window over your VI front panel, then move it back, you'll see the cluster contains the correct data.
This problem seems to be fixed in the next LabVIEW release.
-D
Along with the screen redraw mentioned by Darren, it also appears to go away when you take the Event Structure out. The attached code is identical to yours, without the event structure.
Download File:post-3266-1143734396.vi
The next LabView release being 8.1? The problem is still there in 8.0.1, so I'm assuming you're beta testing ;)
