Cool-LV Posted April 17, 2006 Report Posted April 17, 2006 Hello all, Do you know how to skip administrator's privileges fori nstaller created LV7.1 ? when I start to install, System will querie me to provide an administrator's privileges, Please help to see enclosed, and I found the installer created at LV7.0, it is no need administrator's privileges. can some setting to skip this privileges with LV7.1, or Can LV8.0 do this? I cann't find ? thanks a lot . Quote
didierj Posted April 20, 2006 Report Posted April 20, 2006 If your installer works, depends on what your privileges (of your user-account) are and what you want to install. - "Installing" an app (with user privileges) by just copying some files to a repository will work most probably. - Installing the runtime engine won't work, since the installer has to write some registry keys into a section you don't have write access (HKLM) as simple user. Skipping privileges that are system-wide from inside an app is not possible. Newer Installer allow to check privileges and on install time pop up a box allowing to select a different account, but this would mean that you have to build your installer by yourself (with e.g. InstallShield). The only workaround I see, is to log in as administrator (if you work in a "big" company you'll most probably have to ask your computer-admin to do the job). Didier Quote
Cool-LV Posted April 21, 2006 Author Report Posted April 21, 2006 If your installer works, depends on what your privileges (of your user-account) are and what you want to install.- "Installing" an app (with user privileges) by just copying some files to a repository will work most probably. - Installing the runtime engine won't work, since the installer has to write some registry keys into a section you don't have write access (HKLM) as simple user. Skipping privileges that are system-wide from inside an app is not possible. Newer Installer allow to check privileges and on install time pop up a box allowing to select a different account, but this would mean that you have to build your installer by yourself (with e.g. InstallShield). The only workaround I see, is to log in as administrator (if you work in a "big" company you'll most probably have to ask your computer-admin to do the job). Didier Thanks didierj, it seems that I have to call administrator for this installation help. Quote
