How can i use the putty
Hi everybody
Now i am doing a test using putty ,how can I control the putty use by labview and catch the result to analysis it?
Thanks of lot
Since putty is a command line tool you will want to control it through its standard IO. This can be best done by redirecting its standard IO to pipes and communicate through them. LabVIEW for Unix platforms comes with a pipe library that allows to do this.
I have attempted to develop a similar solution for Windows and made it available on OpenG. But it is still in Beta stage and probably has some issues but works for more simple solutions. It is not yet released as OpenG package so you will have to get the DLL and VIs from the sourceforge CVS server or its web interface at http://cvs.sourceforge.net/viewcvs.py/open...it/pipe/source/
Rolf Kalbermatter
