xcontrol: correct reference transfer on xcontrol in any subroutine for access to property/methods is necessary.
Hi all,
If we have the link on xcontrol, then we have access to xcontrol-property and xcontrol-method. However if for any subroutine make control-input="xcontrol referency", then in subroutine will be accessible only standard property and methods. Individuality xcontrol will be lost. There can be it a mistake, or can be - ideology. In any case it reduces convenience.
Hmmm, seems to work as expected here..
You should make sure that the reference is a reference to your particular XControl type. If your reference is a generic control reference it's logical that you will only see the methods and properies that are common for all (X)Controls.
You can easily create the correct reference by dropping a control ref. on your FP and then drag-and-drop the XControl on top of that to create a strictly typed reference for your XControl.
Hope this helps.
post-906-1147443149.jpg?width=400
