grmc Posted May 16, 2006 Report Posted May 16, 2006 Has anyone tried the Serial Break function in LV8? I tried both the function and the example, and neither seem to be working?? It was working on the same machine in LV 7.1... Quote
Louis Manfredi Posted May 16, 2006 Report Posted May 16, 2006 Had some problems establishing comm. with some stepper motor drivers back when I was using LV8. These problems might have been partially explained by a non-functional break command. Problem was solved after I upgraded to LV 7.1.1, but I changed a number of other things troubleshooting the problem, so I can't say for sure that a bad break command was the cause. If it does turn out however that the break command is N.F. in LV 8, that would explain a lot for me. Hope someone can give you a more definitive answer. Best regards, Louis Quote
pallen Posted May 16, 2006 Report Posted May 16, 2006 A recent project of mine that started out in LV 7.1 and was then migrated to 8.0 used the Serial Break VI and it seemed to work fine in both versions. As part of earlier troubleshooting, I upgraded my VISA to the newest version. http://digital.ni.com/softlib.nsf/webcateg...&node=132060_US Although I believe I used 3.5. Quote
grmc Posted May 16, 2006 Author Report Posted May 16, 2006 A recent project of mine that started out in LV 7.1 and was then migrated to 8.0 used the Serial Break VI and it seemed to work fine in both versions. As part of earlier troubleshooting, I upgraded my VISA to the newest version. http://digital.ni.com/softlib.nsf/webcateg...&node=132060_US Although I believe I used 3.5. I think you're right. I was using Agilent IO Suite 14.1 - I installed NI Visa drivers (rev 3.4) from the LV disk and all works fine now. I wonder why the Agilent VISA driver no longer handles Serial Break in LV 8.x.x? Quote
